2004 Pontiac Grand Prix Engine stalls at startup after inta
CHECKEDGOLDTOP
  • 2004 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 80,000 MILES
I just changed lower intake gaskets and when I start the car it stalls immediately. The security light is not on. I disconnected the battery during the repair. The gaskets seem to be seated properly and all electrical connections appear to be hooked back up. It is a 3.8 non supercharged with the aluminum plenum. Please help.
EDIT-Nevermind, forgot to attach the brake booster vaccum line. Started on first try. Whoops.
My evap. Code went away with the gasket swap too. Woohoo!
Do you
have the same problem?
Saturday, January 9th, 2010 AT 9:25 PM
MMPRINCE4000
  • EXPERT
Check your brake booster line :).
Sunday, January 10th, 2010 AT 8:00 AM
Recommended Guides
