2002 Pontiac Grand Prix White Foam in the cooling system
JUTRIC
  • 2002 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 63,500 MILES
I have a 2002 pontiac grand prix, 3.1L engine.
Recently I have coolant replace at the quick fluid place. Technician noticed that old coolant is 'milky' and suggested cooling system be flushed.
Again I could see white foam underneath the radiator cap. There is no water in the motor oil.
Is this white foam caused by motor oil entering the cooling system? What part might be demaged?
Thanks for the answer.
Do you
have the same problem?
Saturday, January 26th, 2008 AT 9:12 PM
BLACKOP555
  • CERTIFIED MECHANIC
  • 10,368 POSTS
Sounds like a headgasket failure, you can test it by performing a compression test on the cylinders. The lowest cylinder should be no more then 25% of the highest cylinder.
Saturday, January 26th, 2008 AT 9:53 PM
