2001 Pontiac Grand Prix Brakes are knocking
THETAXI61
  • 2001 PONTIAC GRAND PRIX
  • 6 CYL
  • 145,000 MILES
When turining and braking quickly at the same time I can feel a knocking in the brake pedal and I hear a loud repetitive clicking sound. I can not tell which side the car is causing the sound. I also feel a slight resistance in the brakie pedal, which seemed to be very easy to press in the past. Can you help diagnose this for me?
Do you
have the same problem?
Friday, May 22nd, 2009 AT 12:43 AM
JLBDALLASTEX
I am just a 2000 Grand Prix owner (not a mechanic), but wanted to share my experience. It only happened once but I managed to cause the anti-lock brake system to kick in under hard braking in a construction zone where there were loose gravel scattered on the road. It was a very fast repetitive clicking sound and I could feel some slight vibration in the brake pedal. Perhaps it is something to do with the ABS system?
Also given your mileage, I would guess having brakes checked. The pads may simply need to be replaced. Even if you have already replaced them once before, you have enough mileage it is a conceivable possibility.
Any brake repair shop should take 5 minutes and look at them for free to tell you (at least I know Midas will). If it is just pads needed should be about $100. The thing to be aware of is that if the pads are worn to the point that a metal part is touching the brake rotor, dont wait to get new pads on it or the cost goes up dramatically.
If only a small issue, they can "machine" the rotors which means scape them smooth again (like sanding them smooth to remove any scrapes but done by a machine). If it is a serious issue, they may suggest replacing the rotors and this gets expensive so dont let the issue continue.
. One cheerful and cheap suggestion: check the brake fluid level. It may just need $1 worth of fluid added; perhaps it is low and gravity is causing it because of the turning.
Sunday, May 24th, 2009 AT 11:21 AM
THETAXI61
Thanks for the tip!
Sunday, May 24th, 2009 AT 5:49 PM
Recommended Guides
