1999 Pontiac Grand Prix wont start
BUDDHA6940
  • 1999 PONTIAC GRAND PRIX
  • 6 CYL
  • FWD
  • 120,000 MILES
Did a scan on my 1999 grand prix 3.8l and po300 code came up, says random/multiple cylinder missfire detected. Where do I start/ check first.
Do you
have the same problem?
Wednesday, June 10th, 2009 AT 9:38 AM
P0300 random misfires normally means vacuum leaks and bad fuel
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel
Wednesday, June 10th, 2009 AT 9:53 AM
Recommended Guides
