1995 Pontiac Grand Prix fuel pump
KYPRINCESS5
  • 1995 PONTIAC GRAND PRIX
Electrical problem
1995 Pontiac Grand Prix 6 cyl Front Wheel Drive Automatic
I just replaced the fuel pump in the tank, and my new one is running all the time, is it supposed to?
Do you
have the same problem?
Tuesday, July 22nd, 2008 AT 10:10 AM
JACK42
  • EXPERT
When you say running all the time, do you mean with the key off? If so, could be a problem with the wiring at thepump or a shorted relay, try swapping the fuel pump relay for the a/c relay and see if it fixes it. If not, you may need to drop the tank again to see what is shorted causing it to run all the time
Tuesday, July 22nd, 2008 AT 11:39 AM
