CV Drive Axle
MATTPANTS
  • PONTIAC GRAND AM
Pontiac Grand Am 1997 145,000 Miles, 2.4L 4 cylinder, 5 spd.
I recently got my car serviced for a 'clicking' noise coming from my driver's side tire. I had a new CV Drive Axle put in, yet the 'clicking' continues. However, it does seem to be a little different. Before it seemed to be mostly pretty constant. Now, however, I here it specifically when accelerating to highway speeds, coasting at highway speeds in neutral. And braking to a slow stop. Some of these instances it seems louder than before. Did they not fix enough? Not fix correctly? Does this part need an initial 'wear-in' period?
Do you
have the same problem?
Wednesday, June 6th, 2007 AT 10:14 PM
CAR_PROBLEM
You may check the bearing on that side, too.
Thursday, June 7th, 2007 AT 9:29 PM
Recommended Guides
