95 Pontiac rear brakes
PHIL
  • 1995 PONTIAC GRAND AM
I have a question on my daughters 1995 Pontiac Grand Am. The back brakes apply hard when braking at low speeds lowering the back end of the car. I noticed on one of you previous question you said to replace rear brake shoes and springs and check drum for being oversized. My question is I had the same problem but before fixing it I had to replace the front lower control arm bushings and after I finished I test drove the car and the problem with the rear brakes was gone. She drove the car for a few weeks and then the problem came back. Do you still think the answer above would be the way to go or the Brake Distribution Valve would be the way to go?
Do you
have the same problem?
Sunday, January 1st, 2006 AT 9:05 PM
JACK42
The 1st answer
Wednesday, January 11th, 2006 AT 5:59 PM
Recommended Guides
