2004 Pontiac Grand Am front door lock actuator
MISTIEBLUERN
  • 2004 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 113,000 MILES
Hi, my door lock actuator on the drivers side front seems to be broken. The bar that hooks the outside door handle seems to be unattached from the lock actuator. It is behind the metal door panel and very difficult to get to. The door will not latch closed. Any suggestions? Thanks
Do you
have the same problem?
Saturday, August 29th, 2009 AT 7:18 PM
MMPRINCE4000
  • EXPERT
Check for 12V at door lock switch, if present, then lock solenoid or as you suggest a mechanical connection.
You will have to remove the interior door panel to fix this.
Sunday, August 30th, 2009 AT 7:10 AM
