2003 Pontiac Grand Am fuel system
RGATES66
  • 2003 PONTIAC GRAND AM
  • 4 CYL
  • 83,000 MILES
Last night(6/26 )I was driving on the freeway when I expericned a loss of power. At first I thought tranny. But after I manged to pull over. The car died, I had good juice since I just bought a battery 6/25 and had the alt check. After doing a quick check. Jucie -good starter and craking- good and it would start but die again. So I'm thinking "Fuel" either fuel filter wich does probably need to be changed. ( Will a cloged fuel filter cause the engin to run for a few seconds and die. Or should I go straight to the fuel pump? I hope you have some other ideas I can check before spending $200+
Do you
have the same problem?
Saturday, June 27th, 2009 AT 2:10 AM
Check the fuel pressure to rule out the fuel pump
Saturday, June 27th, 2009 AT 2:14 AM
Recommended Guides
