2002 Pontiac Grand Am OIL CHANGE LIGHT COMEING ON
PISTON
  • 2002 PONTIAC GRAND AM
  • 6 CYL
  • FWD
  • 80,000 MILES
WHAT WOULD CAUSE THE OIL CHANGE LIGHT TO COME ON AFTER OIL CHANGE HAS BEEN DONE?
Do you
have the same problem?
Monday, March 24th, 2008 AT 11:09 PM
TDTHOM
After a oil change is the oil life reset being done?
With the key on and engine off push the throttle padel to the floor 3 times within 5 sec.
The oil change light will flash for about 5 sec. Then go out.
Turn ignition off then start car, light should go off if it stays on try this again.
If you still have problems the fault mybe in the cluster and would need repacing
hope this helps
Tuesday, March 25th, 2008 AT 8:38 PM
Recommended Guides
