2001 Pontiac Grand Am finding
CDSCHAFFER
  • 2001 PONTIAC GRAND AM
Engine Performance problem
2001 Pontiac Grand Am 4 cyl Two Wheel Drive Automatic
where would I find the fuel pressure regulator and the idle control valvue cause I need to replace them on my car. If u could let me know how to locate those I would greatly apperciate that. Thank your for your time
Do you
have the same problem?
Thursday, January 21st, 2010 AT 1:57 PM
TOOOMANYTOYS
The fuel pressure regulator is located on the end of the fuel rail. Its held in with a torex head screw and has the return line screw in it from the bottom with a large fitting. The idle control? Do you mean the idle air control? If so this is located on the throttle body below the throttle cable its held in with two small torex bit screws. It is circular looking.
Thursday, January 21st, 2010 AT 2:08 PM
Recommended Guides
