2000 Pontiac Grand Am running only on #2 and #4 cyclinders
STEVEMEGAN
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 150,000 MILES
I also have a 1999 chevy malibu that is doing the same thing no fire on 1 and 3 cyclinders has a new set of coil packs, module and plugs. I found that 1 and 3 weren't hitting by pulling injector connectors off of the injectors used noide light to check connectors they are getting fire. I then pulled fuel rail and cranked engine all injectors sprayed fuel. I did a compression check on all cyclinders and all were 125 lbs. On the malibu I checked the timing marks and all were good. I've pulled the codes and just got random cyclinder misfire codes. I have a book on both cars but it doesn't tell if the computer has quad drivers built in it. I'm not a fan of the 2.4L but these cars are in really good shape. I like to get them fixed before wife makes me get rid of them. Thanks for your help
Do you
have the same problem?
Saturday, June 27th, 2009 AT 12:17 AM
Check and test the crankshaft position sensor
Saturday, June 27th, 2009 AT 12:29 AM
Recommended Guides
