Radiator fan switch
MICHAEL1984
  • 2000 PONTIAC GRAND AM
  • 6 CYL
  • 111,000 MILES
Does a 2000 pontiac grand am gt have a radiator fan switch? And if so. Where can it be located at.I did a engine test cause my fans not working. Only works when a/c is on. And the code says radiator fan switch.
Tuesday, June 21st, 2011 AT 1:38 AM
SATURNTECH9
  • 30,870 POSTS
What is the exact code number you have?Codes just don't say replace a certain part usually there is some trouble shooting in between the code and changing parts. But yes you do have a coolant temp sensor that tells the computer to turn the fan on at a certain temp.
See the wiring diagram attached below
Tuesday, June 21st, 2011 AT 1:55 AM
WRENCHTECH
  • 20,757 POSTS
It doesn't have any switch. It utilizes the same coolant temp sensor that the computer uses for everything else. It is a 2 speed fan system that uses 3 relays to operate. These fans are programmed to trigger at a higher than normal temp and many people think there is a problem when there really isn't.
Tuesday, June 21st, 2011 AT 2:03 AM
SATURNTECH9
  • 30,870 POSTS
The coolant temp sensor is right where the upper radiator hose goes on the engine screwed into the housing.
MICHAEL1984
  • 8 POSTS
Ok thanx.I replaced the coolant temp switch. And checked everything and the fans don't come on. Please tell me what else could it be. And even when the engine get real hot and the temp needle goes past the half mark the fans still don't come on.
Tuesday, June 21st, 2011 AT 2:13 AM
SATURNTECH9
  • 30,870 POSTS
What was the exact code number your car has it could really be helpful helping you?Also do you have a temp gun that can measure surface temp?How about a multimeter?
Tuesday, June 21st, 2011 AT 2:27 AM
LANCE JAMES
Does that go for 2002 Grand am also.
Thursday, February 16th, 2017 AT 8:16 PM
LANCE JAMES
Im getting the same problems as Michal 1984 all relys are good temp sensor good my fans are still not coming on!Please help thank you.
Thursday, February 16th, 2017 AT 8:25 PM
CARADIODOC
  • 33,741 POSTS
You need to start a new question, and PLEASE list the correct engine size and mileage. This thread is a private conversation between the three people involved. When you piggyback on this post, none of the other experts will see your addition or have a chance to reply. That does you a disservice.
As Wrenchtech stated, there is a coolant temperature sensor, never a switch, that tells the Engine Computer what the coolant temperature is. Based on that, the computer turns on one or more relays to run the fan motor. On many models those relays are bypassed and the fan is run directly, (through a different relay), when the AC system is turned on. That is to provide as much cooling as possible, without having to wait for a certain coolant temperature to be reached. The AC system runs in defrost mode too when the heater is being used.
There were some car models that did indeed use a coolant temperature switch for the radiator fan motor. Those were mostly on import cars in the '70s and '80s. Every model I can think of since the late '80s uses a temperature sensor, and the Engine Computer is programmed to turn the fan on at a preset temperature. That is commonly 210 degrees on Chrysler products, and it turns off at 198 degrees. Many GM computers don't turn the fan on until as high as over 225 degrees. While that "input" sensor system is pretty universal, there are many variations of output circuits. They can include a single relay for simple on or off, two relays for high or low speed, and a computer module to run the motor with "pulse-width modulation". PWM provides for continuously-variable speed from fully-off to full high speed. Those are used to reduce fan noise at low speeds
The original diagnostic fault code number was requested, but never listed. It was also stated here, quite accurately, that fault codes never say to replace parts or that one is bad. They only indicate the circuit or system that needs further diagnosis, or the unacceptable operating condition. To add to the misery, temperature sensors have an extremely low failure rate because there is just one component in them. Failures in the circuit are much more commonly caused by corroded or stretched terminals, or cut or grounded wires.
A quick way to test the circuit on many models is to unplug the coolant temperature sensor while the ignition switch is on. That will set a diagnostic fault code, but what you're looking for is the fan should turn on. The Engine Computer won't know coolant temperature, so it turns the fan on as a precaution to insure overheating doesn't occur. If the fan doesn't turn on, it is likely the problem is in the high-current circuit, meaning the relay's contacts, wiring, and fuses. If you have a low-speed relay and a high-speed relay, as Wrenchtech described, it is unlikely both circuits developed a problem at the same time unless a fuse device they have in common has blown. The suspect for that is a tight fan motor. You can identify that by spinning the fan blade by hand. It should coast to a stop after multiple revolutions.
Related to unplugging the sensor, if there's an intermittent connection anywhere in that circuit, the symptom will be the fan motor is running all the time and / or when it's not needed. That is the opposite of not running at all. That means the cause of this problem is not in the sensor circuit. It has to be in the output circuit. Mechanics use a scanner to talk with the Engine Computer and command it to turn on the fan relay(s). That allows us to troubleshoot the circuit without having to wait for the engine to warm up.
One last comment of great value; be aware that all coolant temperature sensors, ambient or intake air temperature sensors, and battery temperature sensors have two wires because their ground circuits are monitored too. If you find a coolant temperature sensor with only a single wire, that is for the dash gauge. Even that has changed now on newer cars. Now, the instrument clusters get their information from the other computers, not from their own sensors.
Friday, February 17th, 2017 AT 5:36 PM
BRUCE101654
  • 6 POSTS
Engine Cooling problem
2000 Pontiac Grand Am 6 cyl Two Wheel Drive Automatic
i cannot get either of the radiator cooling fans to come on. The fuses are good and the relays are good. If it the ecm where is it located. There is a module under the glovebox what module is it.
Wednesday, April 10th, 2019 AT 6:15 PM (Merged)
BLACKOP555
  • 10,371 POSTS
Your going to want to find the cooling temp switch. Unplug it and jump the two terminalls the fans should come on. If not the fan is bad or the vehcile isnt sending power and ground to the fan. Maybe bad wire if it does the switch is most likely bad
BRUCE101654
  • 6 POSTS
I replaced the cooling temp switch the gauge works no power to either fan
FAMILYLIFE
Does your fans come on when u turn on your a c?
BLACKOP555
  • 10,371 POSTS
One sensor controls the temp guage. Other for cooling fan operation and fuel mixture adjustments
FAMILYLIFE
Which sensor controls the fan. Please tell me the name so I can test it. Thanks
BLACKOP555
  • 10,371 POSTS
https://www.2carpros.com/forum/automotive_pictures/66751_Graphic_4.jpg
BRUCE101654
  • 6 POSTS
No fan when ac on but ac low on freon where is the temp sensor for fan located also the sensor for the ac cooling fan
BRUCE101654
  • 6 POSTS
I unplugged the temp sensor fan came on turned ac on both fans run as long as sensor unpluged any ideas
BLACKOP555
  • 10,371 POSTS
Sounds to me like the temp sensor may be bad?
FAMILYLIFE
I repalced it twice now so I know that is not it. Replaced air temp sensor also. Need another idea please.
MICHAEL1984
  • 8 POSTS
  • 6 CYL
  • 109,000 MILES
My cooling fan only comes on when I turn on the A/C.I changed the temp sensor I checked the fuses and relays. But they don't come on like the should when the A/C off. Would could be the problem. The car is a 2000 pontiac grand am GT.
