2000 Pontiac Grand Am car won't start batt seems ok
KEN BLACKMON
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 143,000 MILES
Just had my fuel pump replaced and was driving when the batt light came on, a few seconds later the ABS light, and then airbag light followed by all warning lights coming on at every bump or braking, while the gauges all went to zero and the interior lights(mileage and radio) got dimmer. As I was pulling in my driveway the gauges all maxed out for a second and then dropped back to zero. Now the car won't start.
Do you
have the same problem?
Tuesday, May 12th, 2009 AT 11:41 PM
NATRONERACER
[quote="Ken Blackmon"]Electrical problem
2000 Pontiac Grand Am 4 cyl Front Wheel Drive Automatic 143000 miles
I would alway check the battery conection first the side mount bolt in terminals are know for haveing conection problems(corosion, loose bolts, and bolts stripping out) I had problems off and on with my grand am usually about once every year or two.
Tuesday, May 26th, 2009 AT 11:16 PM
Recommended Guides
