1999 Pontiac Grand Am Ignition lock cylinder
MARTHA J
  • 1999 PONTIAC GRAND AM
Interior problem
1999 Pontiac Grand Am Two Wheel Drive Automatic
The ignition switch will not turn. It is located on the dash rather than the steering column. How do you remove the lock cylinder & replace it. Thank you for your help.
Do you
have the same problem?
Tuesday, May 18th, 2010 AT 7:25 AM
BLUELIGHTNIN6
  • EXPERT
IGNITION LOCK CYLINDER
You must use a scan tool to perform the BCM theft deterrent relearn procedure whenever you replace the ignition switch lock cylinder.
Disconnect negative battery cable.
Remove instrument panel (I/P) accessory trim plate.
Insert the key to the ignition lock cylinder.
Remove the ignition lock cylinder from the switch:
A. Using a small curved tool or an L-shaped hex wrench, depress and hold the detent on the ignition lock cylinder. If you cannot locate the detent with the tool, remove the radio. View the detent through the radio opening.
B. Turn the key to the ON/RUN position.
C. Pull the ignition lock cylinder out with the key.
Remove the key from the lock cylinder.
If the cylinder does not rotate or is seized, follow the procedure in the ignition switch replacement.
To install:
Insert the key and turn the lock cylinder to the ON/RUN position.
Install the lock cylinder to the ignition switch. If you turned the key slightly while removing the lock cylinder, you may have to align the white colored ignition switch rotor (1) with the lock cylinder (2). You can rotate the ignition switch rotor (1) with your finger.
Turn the key to the OFF position and remove the key.
If necessary, install the radio.
Install the I/P accessory trim plate.
Connect the negative battery cable.
If a new lock cylinder was installed, perform the BCM theft deterrent relearn procedure.
IGNITION SWITCH
Disconnect the negative battery cable.
Remove the instrument panel (I/P) accessory trim plate.
Remove the I/P cluster.
Remove the bolts from ignition switch.
Reposition the ignition switch for ease of removal.
Insert the key and turn the ignition lock cylinder to the ON/RUN position.
Depress the transaxle park/lock cable retainer to release, then pull to remove the park/lock cable from the ignition switch. Perform the following procedure to remove the ignition lock cylinder from the ignition switch:
A. Depress and hold the ignition lock cylinder detent.
NOTE
Remove the ignition lock cylinder before you remove the Passlock- electrical connector.
Disconnect the Passlock- electrical connector from the ignition switch.
Disconnect the electrical connectors from the ignition switch.
Remove the ignition switch through the I/P cluster opening.
If the lock cylinder does not rotate or is seized, perform the following procedure:
A. Protect the immediate work area with suitable material such as clean shop towels or a clean fender cover.
B. Locate the surface for the ignition switch lock cylinder release button (2) on the plastic ignition switch housing and center punch a location (1) on the rib 9.5 mm (3/8 in) rearward, toward the key entry end, from the cylinder release button.
C. Carefully drill a pilot hole through the plastic housing with an 1/8-inch drill bit.
D. Carefully drill a larger hole at the pilot location, and slightly into the ignition switch lock cylinder surface to break the release button retaining spring using a 9/32-inch drill bit.
E. Remove portions of the broken spring from the hole using a small suitable tool.
F. Grasp the ignition switch lock cylinder and remove the cylinder from the switch housing.
G. Remove any plastic flashing from the drilling operation, and using compressed air blow out the ignition switch assembly.
H. Follow the service procedures when cylinder coding is required.
To install:
If the lock cylinder would not rotate or was seized, perform the following procedure:
A. Install the new ignition switch lock cylinder as required by rotating both the cylinder and the ignition switch to the ON position.
B. Push the lock cylinder into the ignition switch housing until fully seated.
C. You may need to slightly depress the release button as the cylinder passes by the 9/32-inch hole previously drilled in the ignition switch housing.
Position the ignition switch into position through the I/P cluster opening.
Connect the electrical connectors to the ignition switch.
Connect the Passlock- electrical connector to the ignition switch.
Connect the park/lock cable to the ignition switch.
Install the ignition lock cylinder. If you turned the key slightly while removing the lock cylinder, you may have to align the white colored ignition switch rotor (1) with the lock cylinder (2). You can rotate the ignition switch rotor (1) with your finger.
Position the ignition switch to the I/P.
Install the bolts to the ignition switch. Tighten the bolts to 53 inch lbs. (6 Nm).
Install the I/P cluster.
Perform the Passlock- learn procedure:
A. Turn ON the ignition, with the engine OFF.
B. Attempt to start the engine, then release the key to ON (vehicle will not start).
C. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
D. Turn OFF the ignition, and wait 5 seconds.
E. The vehicle is now ready to relearn the Passlock- Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK.
NOTE
The vehicle learns the Passlock- Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
F. Start the engine. The vehicle has now learned the Passlock- Sensor Data Code and/or password.
G. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
Wednesday, May 19th, 2010 AT 12:35 AM
Recommended Guides
