1999 Pontiac Grand Am engine cooling fans
DJCOBRA4
  • 1999 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 177,000 MILES
My cooling fans on my '99 grand am do not work which causes my engine to run hot on occasions. Is there a quick fix for this?
Do you
have the same problem?
Saturday, November 8th, 2008 AT 1:11 PM
BLACKOP555
  • EXPERT
A quick cheap fix or a proper fix?
Quick fix would be be to hook a toggle switch up and run it directly from the battery and you can flip it on, either that or run a wire to something that gets power with key on that way it runs all the time with engine on.
Or you can find out whats wrong and fix it, will cost more but its the right thing to do.
Saturday, November 8th, 2008 AT 2:25 PM
Recommended Guides
