1998 Pontiac Grand Am engine wont crank
DONCONKLIN
  • 1998 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 153,000 MILES
I replaced the ignition and had a lock smith instal it But car will still not crank. Locksmith was sure this was the problem. Spent 264.00 on ignition so cant spend too much more on it. What else could be wrong?
Do you
have the same problem?
Wednesday, February 6th, 2008 AT 8:55 PM
BMRFIXIT
  • EXPERT
Is your security light blinking?
If so scan BCM for codes
did you check to start the car in Neutral (checking neutral safety switch )
have you checked the starter
let me know
Wednesday, February 6th, 2008 AT 9:06 PM
DONCONKLIN
let me know[/quote:5c01173586]
Thanks for the help.
I checked all the above and no luck. One question the security light stays on all the time. Wew checked all the cable connections to the starter and even the ground and still no luck. Nuetral safety switch was not problem. Still confused
Thursday, February 7th, 2008 AT 2:00 PM
BMRFIXIT
  • EXPERT
let me know[/quote:1ef58f1447]
I checked all the above and no luck. One question the security light stays on all the time. Wew checked all the cable connections to the starter and even the ground and still no luck. Nuetral safety switch was not problem. Still confused[/quote:1ef58f1447]
OK ;lets try this
make sure car in park and e brakes on
turn key to on then jump the starter
let me what happen
if car start and run
Thursday, February 7th, 2008 AT 5:12 PM
Recommended Guides
