1996 Pontiac Grand Am starter won't crank
BOBD1075
  • 1996 PONTIAC GRAND AM
  • 6 CYL
  • 180,000 MILES
Turn key, lights come on, but starter won't move. Verified battery is good, starter is good, but no start signal voltage to starter solenoid.
The key switch has light gage wires, so there must be another solenoid or control module. If so, where is it located so that we can remove it and check.
Any other suggestions?
Do you
have the same problem?
Friday, May 1st, 2009 AT 9:44 PM
Test the park and neutral position switch
Friday, May 1st, 2009 AT 10:21 PM
Recommended Guides
