1996 Pontiac Grand Am computer
JESSICAT1988
  • 1996 PONTIAC GRAND AM
  • 6 CYL
  • 171,000 MILES
Does your anti-theft device run through your electronic control module, or your body control module?
Do you
have the same problem?
Tuesday, December 8th, 2009 AT 9:55 PM
JDL
  • EXPERT
Welcome to the forum, you have passlock. Passlock is injector disable, if the security system has a problem. Components, passlock cylinder-- instrument cluster-- pcm. If the pcm receives proper data signal from instrument cluster, the pcm will enable fuel injector/s. The wiring circuits could also cause a problem. Have all the codes checked, see if a code points to anything?
Wednesday, December 9th, 2009 AT 3:53 PM
Recommended Guides
