Camshaft and timing chain marks and timing?
TJJEANES
  • 2001 PONTIAC GRAND AM
  • 2.4L
  • 4 CYL
Set timing chain
Do you
have the same problem?
Wednesday, August 27th, 2014 AT 11:15 AM
HMAC300
  • 48,606 POSTS
Seepic for marks/location
Thursday, August 28th, 2014 AT 6:48 AM
TJJEANES
Thanks
Thursday, August 28th, 2014 AT 7:31 AM
JAMES WOOTEN
  • 2000 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • 187,000 MILES
How to set timing marks for the timing chain?
Monday, June 14th, 2021 AT 10:29 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Here is the timing marks if that is what you were needing.
FOGUIE MCKINNIE
  • 50 POSTS
  • 102,305 MILES
I have a 2000 pontiac grand am I need timing chain diagram
HMAC300
  • 48,606 POSTS
Here ya go this is for a 3.4L as you didn't give engine size 2nd one with 2 cams is for a 2.4L next time give engine size.
2CP-ARCHIVES
  • 4,544 POSTS
How to set timing marks?
HMAC300
  • 48,606 POSTS
Here is the timing marks for the timing chain and camshafts. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
JOYCE ROBERSON
  • 1997 PONTIAC GRAND AM
  • 4 CYL
  • 100,500 MILES
I replaced the water pump and afterward I set the timming wrong and broke the valves on two cylinder I had them replace and attempted to reset the timming but when I try to turn the engine over by hand it will only turn about a 180 degree turn
Monday, June 14th, 2021 AT 10:31 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
Pay a close tension to the guides and tensioner
recheck timing marks again
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_110.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_231.jpg
FLYBUZZ67
  • 1996 PONTIAC GRAND AM
  • 4 CYL
  • MANUAL
  • 161,000 MILES
Where do I find the timing marks on a 2.4 ltr dual overhead cam
https://www.2carpros.com/forum/automotive_pictures/12900_timing_27.jpg
SHADOW52
  • 1993 PONTIAC GRAND AM
I changed a blown head gasket. And I can't get the timing right. No compression. Rocker arm cover say's quad 4, but it is not a quad 4. It is one of those quads that were only put in 2% of the vehicles, so I can't find a book or info on it.I need help to get it going. Please! I'm a electrician if anyone needs answers on that subject.
Monday, June 14th, 2021 AT 10:32 AM (Merged)
BMRFIXIT
  • 19,053 POSTS
This is the timing marks hope it's what you're looking for let me know
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_170.jpg
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_366.jpg
PRADOG
  • 1992 PONTIAC GRAND AM
  • 4 CYL
  • FWD
  • MANUAL
  • 49,000 MILES
What are the specificationns for the timing chain marks on a 2 cam, engine?
OBXAUTOMEDIC
  • 3,711 POSTS
Here is the timing alignment....
https://www.2carpros.com/forum/automotive_pictures/188069_92grndamtim4cyldohc_2.jpg
