1995 Pontiac Firebird Fuel System
RICHARDBR
  • 1995 PONTIAC FIREBIRD
  • 6 CYL
  • 90,000 MILES
When I crank the engine it sounds like I'm out of gas and won't turn over to start. I have a full tank, so I know it's not the gas. I changed the fuel filter, but still won't start. Could it be anything other than the fuel pump? How do I test the Fuel Pump Rely?
Do you
have the same problem?
Friday, August 21st, 2009 AT 11:14 AM
JDL
  • EXPERT
Hello, if the vehicle cranks good but won't start, have a helper crank it, while you check for spark at the plugs and injector pulse. If you have both, use a gage and check fuel pressure.
There should be a fuel pump prime connector, behind the battery, gray wire with connector, nothing plugged into it. Use jumper wire with inline fuse, run voltage to the connector, the pump should run. You don't have to use the key.
Friday, August 21st, 2009 AT 11:36 AM
Recommended Guides
