1993 Pontiac Firebird
REN SANTIAGO
  • 1993 PONTIAC FIREBIRD
Engine Cooling problem
1993 Pontiac Firebird V8 Two Wheel Drive Automatic
My car cooling fan only turn on when the AC is running
I check the primary and secondary fan relay, Both are good.
I also replace the 2 coolant temp sensor, One located at the water pump and the other one located at the cylinder head. I also check the fuse and it's good. After doing all this I still come up with the same problem. That's why everytime I drive
my car I have to keep the AC on to keep the car from overheating. Please tell me the next step I should do to fix this problem.
Do you
have the same problem?
Wednesday, February 17th, 2010 AT 7:29 PM
  • EXPERT
Do you have a one or two fan system?
Monday, April 19th, 2010 AT 1:40 PM
Recommended Guides
