1986 Pontiac Firebird wiring
MESHAN
  • 1986 PONTIAC FIREBIRD
  • 6 CYL
  • MANUAL
  • 176,000 MILES
The panel below the dash I took of because I was replacing light relays and the shift linkage when I was done I realized I unplugged a pinkish wire now I just need to know where to put it
Do you
have the same problem?
Sunday, July 18th, 2010 AT 7:30 AM
BLUELIGHTNIN6
  • EXPERT
Hello and thanks for donating
Do you have trouble starting the vehicle now? There is a purple pinkish wire that runs from the clutch pedal switch to the starter. The clutch pedal switch is in the area you described, should be just above the clutch pedal.
Monday, July 19th, 2010 AT 8:06 PM
MESHAN
Yes I am having problems starting the car, it doesnt start. Could you provide me with a diagram on where to put it back.
Tuesday, July 20th, 2010 AT 5:34 PM
BLUELIGHTNIN6
  • EXPERT
Sure here you go..
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_2482.jpg
https://www.2carpros.com/forum/automotive_pictures/261618_Noname2_811.jpg
Thursday, July 22nd, 2010 AT 6:27 PM
