1996 Pontiac Bonneville computer location
DARRELLV
  • 1996 PONTIAC BONNEVILLE
Computer problem
1996 Pontiac Bonneville 6 cyl Two Wheel Drive Automatic 140k miles
This car will crank but not start. No spark No fuel pump No injector fire {test light}. Check eng. Light comes on when turn the key so ecm is getting power. Power seats move, all fuses are good.
Would you hang a ECM on it? WHERE IS THE ECM IN HIS CAR?
Do you
have the same problem?
Saturday, November 8th, 2008 AT 6:23 AM
BMRFIXIT
  • EXPERT
PCM is located Left front corner of engine compartment
I would suspect crank position sensor
and or security system
good luck
let me know
Saturday, November 8th, 2008 AT 6:35 AM
DARRELLV
But if the Crank Sensor was bad. Would it keep the fuel pump from firing up?
Saturday, November 8th, 2008 AT 2:21 PM
BMRFIXIT
  • EXPERT
When 1st key on does the fuel pump work for a few sec
with key ON do u have check engine light ON?
Do u have security light on or flashing
check for codes
check ignition module
Saturday, November 8th, 2008 AT 10:16 PM
DARRELLV
Yes. When I 1st turn the key on. The Check Eng. Light comes on thinking the pcm has power to it Nothing flashes. No Security Light and I tried another key w/chip that we had for the car also. I already took off the Ignition Module and had it checked and it looked good even after I heated it up testing it a dozen times. AND NO THE FUEL PUMP DOES NOT FIRE UP AT ALL. No Fuel. No Spark
Saturday, November 8th, 2008 AT 10:38 PM
BMRFIXIT
  • EXPERT
What about codes do u have any
http://www.2carpros.com/forum/automotive_pictures/99387_Graphic2_25.jpg
Saturday, November 8th, 2008 AT 10:43 PM
DARRELLV
No codes that I know of. My son was driving the car when it died. He never siad anything about any lights etc. Etc. No Codes That I know Of. I don't have any way to check and read the code here myself anyway. But I understand why you ask.
Any ideal about it? WOULDN'T THE FUEL PUMP FIRE UP IF THE CRANK SENSOR WAS BAD? I can hang a crank sensor on it to try. But I'm thinking even if the sensor was ban the fuel pump would run. I'm not getting fire to the injectors or spark at plug wires.
Saturday, November 8th, 2008 AT 11:01 PM
BMRFIXIT
  • EXPERT
Are u sure u have no spark?
When 1st key on the fuel pump should come on (good or bad crank sensor )
I hate for u to replace the PCM come to find out its some thing else
do every test possible because once u buy the PCM you own it.
Check if you have power getting to the fuel pump
and also check the relays
when cranking does check engine light go out or it stay on
checking for codes will help
Saturday, November 8th, 2008 AT 11:30 PM
DARRELLV
No Spark at more than one plug wire. No Injector Pluse with test light. No Fuel Pump running when key turned on. Another key used/Ing. Mod. Tested good also. The ground wires must be ok power seat-windows work still. If Crank Sensore was bad I'd hang another one asap, but with the fuel pump not running I'm not sure it is?
Thinking maybe a PCM. Maybe BCM?
ANY HELP AT ALL IS HELPFUL.
Sunday, November 9th, 2008 AT 12:51 PM
Recommended Guides
