1995 Pontiac Bonneville
FNJACKSON
  • 1995 PONTIAC BONNEVILLE
The back rear tire on the passenger side does not spin
Do you
have the same problem?
Tuesday, February 23rd, 2010 AT 9:27 AM
JDL
  • EXPERT
Hi, I've seen ice freeze up a brake drum to where the wheel wouldn't spin, just slide over the pavement. You may have to safely raise and support the vehicle, remove the tire, see if you see anything? I have removed ice with a hammer and chisel. If there is a brake drum, remove it, take a look. If you don't see anything and the brakes are released, maybe a bearing issue?
Tuesday, February 23rd, 2010 AT 1:21 PM
Recommended Guides
