1998 Pontiac 6000 HELP
ROBJAY
  • 1998 PONTIAC 6000
Electrical problem
1998 Pontiac 6000 6 cyl Front Wheel Drive Automatic
I was trying to fix the brake lights, the car was running and I pulled the ''gauges'' fuse and the car died. I replaced the fuse and it did not start. There is no power to ANYTHING in the cabin no matter what position the key is at. No door chime, dome lamp ect. I tried checking the gauges fuse and all others I could find to see if maybe I shorted something but still no luck. Any ideas?
Do you
have the same problem?
Wednesday, May 6th, 2009 AT 2:28 AM
  • EXPERT
Have you tried disconnecting the battery?
Friday, April 16th, 2010 AT 12:28 PM
Recommended Guides
