1998 Plymouth Voyager
VOYAGERPROBLEM
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • 277,000 MILES
Hi, noticed lately that when you put it in reverse it sputters and shakes as you back up. Now it is also doing it when you put it into drive and start to move. Also, you can hear the sputtering from the tailpipe when behind the vehicle.
I have replaced plugs, wires and fuel filter recently
Do you
have the same problem?
Saturday, July 17th, 2010 AT 5:29 PM
Engine running rough or misfiring can be cause by the following:
1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Saturday, July 17th, 2010 AT 11:13 PM
Recommended Guides
