1998 Plymouth Voyager
CYRUS
  • 1998 PLYMOUTH VOYAGER
  • 6 CYL
  • 235,690 MILES
The car is running you put it in gear drive a short distance then does not move, the engine still running the gear is in drive you push the gas it makes whistling noise, and it doesn't move, you shut it off.
cools down start again same thing happens again.
please tell me what s wrong
Do you
have the same problem?
Monday, January 18th, 2010 AT 11:21 AM
BMRFIXIT
  • EXPERT
Check tranny fluid
check for codes
Wednesday, January 20th, 2010 AT 8:39 PM
Recommended Guides
