1996 Plymouth Voyager Stalling on highway
VTRAN96
  • 1996 PLYMOUTH VOYAGER
  • 6 CYL
  • FWD
  • 110,000 MILES
This is the 2nd time my 3.3L Grand Voyager stalled after 100 miles on the highway in a month (went to the airport both times). Both times going up hill the engine started to sputter and eventually cut off. It will start again and ide rough for 10 seconds and cut off again, eventually not starting at all. Both times I had the air conditioner on, which is the only 2 times it's been on this year. Doesn't happened while driving short distances. After the first incident, the next day when the mechanic went to work on it, it started up fine. I had them change the fuel filter the first time it happened. 90% city miles in the past 5 years and these two occurrences were the longest trips made this year. Thanks for the help.
Do you
have the same problem?
Tuesday, August 5th, 2008 AT 7:01 AM
BMRFIXIT
  • EXPERT
Check crank sensor, ASD relay, fuel pump module
Wednesday, August 6th, 2008 AT 6:40 AM
Recommended Guides
