1994 Plymouth Voyager choke
CAR0808
  • 1994 PLYMOUTH VOYAGER
  • 4 CYL
  • 62,500 MILES
Car does not accelerate at 30 mph but if held to the floor it has full power it also seems the transmission is shifting almost like the choke is stuck is there a choke on this model or do you reccomend a certain cleaner (gumout)?
Do you
have the same problem?
Saturday, March 8th, 2008 AT 9:00 AM
MERLIN2021
  • EXPERT
The "choke" on EFI is the engine coolant temp sensor. Is your check engine light on? If yes turn the key from off to on three times, on the fourth one leave it in the on position, count the flasshes.22 would flash as 2 blinks, then a short puase, then 2 more blinks. If several codes are stored, the pause is longer between codes, code 55 will be the last code. Do this and post all codes found.
Saturday, March 8th, 2008 AT 10:43 AM
Recommended Guides
