1993 Plymouth Voyager fuel pump
GENEHODGE
  • 1993 PLYMOUTH VOYAGER
  • 6 CYL
  • 289,000 MILES
Pump dont work, is there a fuse or fuse link? Where is it?
Do you
have the same problem?
Thursday, January 28th, 2010 AT 12:03 PM
JDL
  • EXPERT
Welcome to the forum. Engine cranking, do you have spark at the plugs? The reason I ask, if no rpm signal, you get nothing. No fuel, no spark. You might check for trouble codes.
As far as the fuel pump, I'd check the circuits at the fuel pump relay. Voltage to the load/switch side of relay is hot all the time. Voltage and ground to the coil side of relay is controled by the pcm.
Thursday, January 28th, 2010 AT 12:43 PM
Recommended Guides
