1988 Plymouth Voyager Shifting
PETER R. CROSS
  • 1988 PLYMOUTH VOYAGER
  • 4 CYL
  • FWD
  • MANUAL
  • 10,000 MILES
Has been out of use--getting it going again, Reverse and 4th Gears will not go in. Shaft does not seem willing to be pushed down, to go to reverse. Knob missing, I recall pattern to be:
Reverse, press directly down, to far left, forward
First, directly forward
Second, directly back
Third, over to right and forward
4th, on right-hand side and straight back.
(Clutch is pretty far down to engage)
Do you
have the same problem?
Friday, May 15th, 2009 AT 6:41 PM
  • EXPERT
Will the transmission shift when the engine is off?
Monday, May 25th, 2009 AT 8:22 PM
Recommended Guides
