1999 Plymouth Neon battery light stays on
DRKILGORE
  • 1999 PLYMOUTH NEON
Electrical problem
1999 Plymouth Neon 4 cyl Front Wheel Drive Manual
replaced battery replaced alt tightend all belts, battery light still stay on. Checked codes, none found
Do you
have the same problem?
Sunday, August 30th, 2009 AT 12:14 PM
JDL
  • EXPERT
Do you think the charging system is ok? I realize the alternator has been replaced, but, sometimes the wiring to or from the alternator maybe faulty. I'd use a digital multimeter, with everything turned off, take a reading across the battery posts. Generic specs say around 12.6 volts is a fully charged battery. Start the vehicle take a second reading, the second should be higher than the first? If it isn't, take a reading at the alternator bat terminal. Is that reading higher than the first?
Sunday, August 30th, 2009 AT 1:37 PM
