HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Plymouth
Breeze
Engine
Symptoms
Not Cranking Over
1998 Plymouth Breeze
CTWILEYUS
MEMBER
1998 PLYMOUTH BREEZE
When I turn the key to start my 1998 plymouth breeze all the dash lights come on but the car wont turn over its like thiers no power
Do you
have the same problem?
Friday, May 25th, 2007 AT 4:41 PM
EXPERT
When battery and connections checks out-could be one of these, Ignition switch, NSS/Inhibitor switch, starter relay and starter.
SPONSORED LINKS
Friday, May 25th, 2007 AT 5:00 PM
Please
login
or
register
to post a reply.
Related Engine Not Cranking Over Content
Turning Over But Not Firing
I Have A 1998 Plymouth Breeze With A 2.0. It Is Turning Over But Not Firing I Have Changed The Crank Sensor, Timing Belt, Cam Shaft Sensor...
Asked by
paiged
1998
PLYMOUTH BREEZE
GUIDE
Not Cranking Over
When your engine is not cranking (turning) over it will be mainly due to three separate areas, first it could be the battery, cables or poor connection, next is the starter...
1998 Plymouth Breeze Car Won't Crank Or Turn Over (...
Car Lights Are Bright, Only The Brake Light And Digital Mileage Lightup On The Dash With Car In Park Or Neutral, But The Whole Dash Lights...
Asked by
SGSINC713
1 ANSWER
1998
PLYMOUTH BREEZE
1998 Plymouth Breeze Engine Wont Crank, All Lights Work In Dash, Battery Is Good, Not A Sound Trying To Start
Asked by
pickett1976
1 ANSWER
1998
PLYMOUTH BREEZE
1998 Plymouth Breeze Can't Start My Breeze:(
Hi, Iv Having Difficulty's Starting My Breeze It's Been Garage Kept For About A Year Now And It's Got A Fresh Battery But It's Not Turning...
Asked by
937
1998
PLYMOUTH BREEZE
No Crank Situation
Ok.I Have A 99 Breeze With A 2.4ltr Engine. I Just Replaced The Motor And On The 4th Day I Drove It. Ran Into The Store To Get Something....
Asked by
phate1606
1999
PLYMOUTH BREEZE
VIEW MORE
SPONSORED LINKS
Battery Replacement
Starter Replacement
How to Test a Car Battery
Online car repair manuals
