1992 Plymouth Acclaim Engine stalls at speed
DILLIGAF5
  • 1992 PLYMOUTH ACCLAIM
Engine Performance problem
1992 Plymouth Acclaim 6 cyl Two Wheel Drive 105000 miles
The engine will return to idle at speeds when I am driving up to 45mph. If I turn the ingnition off and back on it will run normally for a few miles then back to idle again.
Do you
have the same problem?
Thursday, January 1st, 2009 AT 2:21 PM
CHALLENGERBOY
When you stomp on you gas pedal what happens?
Monday, January 12th, 2009 AT 4:19 PM
Recommended Guides
