Plastic rocker panel trim is loose
DAVID GREGOIRE
  • 2001 PONTIAC GRAND PRIX
  • 3.8L
  • V6
  • FWD
  • 130,000 MILES
The plastic rocker panel cover on the driver's side is loose. The middle bracket has rusted away. Front and back ones seem solid. It looks like I could put a sheet metal screw through the plastic and into the metal behind.
Is there any wiring or anything behind the metal rocker panel that might be damaged by doing this?
Do you
have the same problem?
Thursday, June 2nd, 2016 AT 9:29 AM
HMAC300
  • EXPERT
No nothing is there, just screw it in if you want.
Thursday, June 2nd, 2016 AT 12:17 PM
Recommended Guides
