Overheating when stopped or going slow
JASON CROSS
  • 2001 HONDA ACCORD
  • 4 CYL
  • 248,000 MILES
My car overheats when I am stopped at a red light or driving really slow. I have replaced my cooling fan and thermostat and cooling fan relay and my car is still having the same problem. I was wondering if it is the cooling temperature sensor in the fuse for the cooling? Fan is good.
Do you
have the same problem?
Wednesday, May 10th, 2017 AT 6:17 PM
CARADIODOC
  • EXPERT
Can you hear if the fan is actually turning on? If it is not coming on, unplug the two-wire coolant temperature sensor while the engine is running. That should force the radiator fan to run as a safety measure. If the fan runs when you do that, the rest of the circuit is okay. The next step would be to observe the actual coolant temperature on a scanner, to see what the engine computer is seeing.
Wednesday, May 10th, 2017 AT 10:03 PM
Recommended Guides
