I have Sentra 160 DOHC, when driving and I want brake, revs come down and car stalls?
DJTAYER
MEMBER
1998 NISSAN SENTRA
300,000 MILES
I have sentra 160 DOHC, when driving and I want brake, revs come down and car stalls?
Saturday, March 24th, 2012 AT 1:44 PM
WRENCHTECH
MECHANIC
First eliminate all vacuum or air leaks in the system. You may have a bad IAC ( idle air control) but try cleaning the throttle body first. Remove the intake snorkel, have someone hold the throttle wide open for you and scrub the back side of the throttle plate and surrounding bore with an old tooth brush and some carb cleaner. Be sure to spray some into the small holes next to the throttle plate. That should help stabilize the idle. If it still has a problem, replace the IAC.
SPONSORED LINKS
Saturday, March 24th, 2012 AT 2:10 PM
DJTAYER
MEMBER
Thanks, how do I replace IAC?
Saturday, March 24th, 2012 AT 2:21 PM
WRENCHTECH
MECHANIC
Do the other stuff first and then worry about that.
Saturday, March 24th, 2012 AT 2:27 PM
DJTAYER
MEMBER
Hi, did what you told me to do, still the same. What now?
Saturday, March 24th, 2012 AT 7:57 PM
WRENCHTECH
MECHANIC
There are no specific instructions for changing the IAC. It's held in by a couple bolts.
SPONSORED LINKS
Saturday, March 24th, 2012 AT 9:49 PM
DJTAYER
MEMBER
Thank you, it worked. Now there's a new problem fuel consumption seems to be a lot, idling is at 2000 rpms, is this normal, I changed the fuel filter, the carburator is okay.
Monday, March 26th, 2012 AT 5:51 PM
WRENCHTECH
MECHANIC
Look for vacuum leaks
Monday, March 26th, 2012 AT 6:06 PM
DJTAYER
MEMBER
Okay thanks, I know it's a vacuum leak, but where do I start?
Monday, March 26th, 2012 AT 6:28 PM
TFJ3038
MEMBER
1 POST
2004 NISSAN SENTRA
1.8L
4 CYL
AUTOMATIC
46,500 MILES
My car has had an overheating problem for little bit, it was not anything major at first. Every now and then the temperature gauge would spike for a little then drop back down. After a week or so a rev limiter would kick in at 2000 rpm's. If I pulled over and let the car sit for a few minutes it would be okay for little while then it would do it again. I replaced the radiator cap and thermostat. Also, when using a code reader it came up as a bad thermostat but even after replacing it it still does it and the temperature gauge stays hot for a longer time before randomly dropping.
