Overheating
JABARRI BRICKHOUSE
  • 2000 FORD TAURUS
  • 3.0L
  • 6 CYL
  • 1,913,456 MILES
My car starts to overheat when it is not moving.
Do you
have the same problem?
Saturday, June 10th, 2017 AT 4:38 AM
CJ MEDEVAC
  • EXPERT
If you have coolant,
If the thermostat is good,
your fans come on,
It could be a water pump failure, it has a plastic impeller that sometimes can shell out.
I have a pic of a bad water pump for a Taurus below.
If yours has done this, and a piece is missing, see if you can find it stuck in the water passage on the engine side.
The Medic
Saturday, June 10th, 2017 AT 11:15 AM
Recommended Guides
