1999 Opel Corsa Cooling fan
GIELO123@MSN.COM
  • 1999 OPEL CORSA
Engine Cooling problem
1999 Opel Corsa 4 cyl Two Wheel Drive Manual
My cars temperature use to be around 90-95 degrees on the gauge. These days the temperature is around 100 degrees and the fan only activates around 100 degrees. I think something is wrong. I had the car in to the dealer which repalced the switch that plugs into the aircon but the condition is the same.
I do use anti-freeze and is scared that the car will get engine damage. I have replaced the sensor that measures the temperature as well as the radiator cap. So far no difference.
Any ideas?
Do you
have the same problem?
Monday, July 20th, 2009 AT 1:10 PM
DAVE H
  • EXPERT
Replace the thermostat !
Sunday, July 26th, 2009 AT 6:49 AM
Recommended Guides
