Hub Assembly 2001 Olds Bravada
JOE51
  • 2001 OLDSMOBILE
I have the "brake" and "abs" light come on. I replaced brakes on all four thinking this would fix the problem. I replaced front-wheel hub assemblies which fixed the lights from coming on. But know they come on intermittently. Do the rear hub assemblies have electrical sensors as do the front? I don't hear any sort of grinding/groaning sounds from the rear. Tired of looking like a Christmas tree on my dash.
Do you
have the same problem?
Monday, June 18th, 2007 AT 7:35 AM
SERVICE WRITER
  • CERTIFIED MECHANIC
As far I see, nothing in the rear. You may have a bad wiring warness or ebcm. OR a defective bearing/hub. Best bet is to find the codes in the computer and go from there.
Monday, June 18th, 2007 AT 9:37 AM
