Have 1993 Olds Bravada 4.3L with Votex engine car about 160,000 miles stalls at idle while driving have to shift to Neutral when stopping or slowing down or car stalls not that hard to start at times. Car also will heistate for a half second at times on expressway but keep going. Have replaced Fuel filter, plugs, rotor, clean ERG valve, shop replaced two relays and ECM. Fuel pump works now shop says ECM is being shorted out by fuel injectors which were replaced 3 years ago. Any idea what problem could be? Service Engine Light comes on even after ERG valve was cleaned. ERG valve costs less than fuel injectors but tried of replacing parts and not solving problem.
Thanks
SPONSORED LINKS
Do you
have the same problem?
Wednesday, January 31st, 2007 AT 12:12 PM
