90 Olds 88 3.8 motor. Temp light
TEAYSVALLEYGUY
  • 1990 OLDSMOBILE
I have a 1990 Olds 88 that has the temp light on. It had a water leak and the water pump was replaced. The fan was iffy so I replaced the motor today. I also replaced the thermostat today.
The temperature light is still comeing on. Any idea of what else I can check. Any help is much appreciated.
Thanks,
George
Do you
have the same problem?
Tuesday, May 15th, 2007 AT 3:37 PM
KM
Maybe check termostate or temp sending sensor
Friday, May 18th, 2007 AT 1:12 PM
Recommended Guides
