1999 Oldsmobile Bravada (WHEELS HOP ON TURNS
DWITT
  • 1999 OLDSMOBILE
I HAVE A 1999 OLDSMOBILE BRAVADA & WHEN IT WARMS UP THE FRONT END WHEEL HOPS BAD WHEN YOU TURN. I REPLACED THE CLUTCH PACS & THEY SHIMMED IT A FEW YEARS AGO. IT WORKED FOR A WHILE BUT NOW IT IS WORSE THAN EVER. I HAD A MECHANIC CHANGE OIL IN TRANSFER CASE BUT THIS DID NOT HELP. IS THEIR A WAY TO FIX THIS WITHOUT REPLACEING THE WHOLE FRONT END (180,000 MILES )THANKS
Do you
have the same problem?
Tuesday, October 16th, 2007 AT 12:56 PM
SERVICE WRITER
  • EXPERT
Sounds like it is stuck in 4 wheel drive.
Wednesday, October 17th, 2007 AT 7:41 AM
Recommended Guides
