1991 Oldsmobile Toronado trofeo will not shift
ISOFAKINGSEXY
  • 1991 OLDSMOBILE
I have a 1991 Oldsmobile Toronado Trofeo, with automatic transmission. While driving from work one day, suddenly I began decellerating slowly. Basically, the car was coasting while in drive. While in drive the car will get to 30 or 40 mph, and will go no faster, it is acting like it will not shift out of 2nd gear. While checking the in dash code readout, it says I have an e.C.M. Problem, and an egr problem, I was wondering if either could cause this particular vehicle to not shift correctly. I never had this problem, or any indications of it beforehand. I thank you for any help you can give me.
Do you
have the same problem?
Friday, August 17th, 2007 AT 4:20 AM
  • EXPERT
Have the ECM tested.
Monday, April 5th, 2010 AT 2:51 PM
Recommended Guides
