1986 Oldsmobile Delta 88
ONEMIDDLE
  • 1986 OLDSMOBILE DELTA 88
  • 6 CYL
  • 98,000 MILES
We were told by auto shop that there was no way to tell if there was a problem with the power steering pump or the lines. They suggested that we replace the pump, hoping that that would fix it. If that isn't it, then we should fix the lines/hose. There is power steering fluid, but the wheel is still hard to turn. Is there a way to find out for sure if the problem is with the pump or the line, so as to avoid fixing something that isn't broken?
Do you
have the same problem?
Wednesday, March 3rd, 2010 AT 10:23 PM
  • EXPERT
Did the problem happen all at once?
Monday, April 12th, 2010 AT 9:49 PM
Recommended Guides
