1998 Oldsmobile Cutlass wire harnest
JASONRIZLEY
  • 1998 OLDSMOBILE CUTLASS
Electrical problem
1998 Oldsmobile Cutlass 6 cyl Front Wheel Drive 91,000 miles
do you have a wire harnest diagram?
Do you
have the same problem?
Friday, June 25th, 2010 AT 12:57 PM
INTERNETMECHANIC
Hi, your question is too broad. Is there a single system that your having trouble with, fuel--ignition--whatever?
Autozone. Com has free wiring diagrams. You have to register your vehicle, it will ask for year--make--model and all that good stuff, then click on vehicle repair guides, surf the links till you find what you want.
I'd be glad to post a diagram for individual system, the whole wiring harness is a bit much.
Friday, June 25th, 2010 AT 2:45 PM
Recommended Guides
