1997 Oldsmobile Cutlass OBD code 301 and little power
DAWNANDMIKEV
  • 1997 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 103,120 MILES
I have a 1997 oldsmobile cutlass with 103,120 miles on it. It has little power with the pedal depressed fully, but kicks in at times, then cuts back out. Worse going up hills. Tested and putting out code 301; #1 cylinder misfire detected. Also eating up the gas. I replaced #1 spark plug & wire, cylinder 1 coil pack and coil pack module, and catylitic converter. Still having same problem. HELP please!
Do you
have the same problem?
Tuesday, April 21st, 2009 AT 9:53 PM
  • EXPERT
Have you checked the compression in that cylender?
Wednesday, May 27th, 2009 AT 12:14 PM
Recommended Guides
