Fuel filter
EDDYMIRANDASR
  • 1998 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 98,665 MILES
Where is the fuel filter
Monday, November 1st, 2010 AT 9:26 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Under vehicle, driver side, below seating area, front of fuel tank, mounted on frame rail in fuel line
Monday, November 1st, 2010 AT 9:38 PM
DANILYNN209
  • 7 POSTS
  • 1997 OLDSMOBILE CUTLASS
  • 3.1L
  • 6 CYL
  • FWD
  • 165,000 MILES
Hi again I need to change the fuel filter on my 1997 Oldsmobile cutlass supreme and haven't got a clue plzzzz help ! I bought the fuel filter but? I'm also a female with no experience any and all advice will be greatly appreciated. You guys have been of great help to me in the past
Thursday, June 27th, 2019 AT 1:29 PM (Merged)
CARADIODOC
  • 33,741 POSTS
As I recall, the fuel filter sits along the right frame rail ahead of the rear wheel. Use a pair of line wrenches, (flare nut wrenches), to loosen the nut on the steel line. That nut is very soft metal and a regular open end wrench will usually round it off. Fuel is going to spray out but it won't be a lot. Wear safety glasses and keep your mouth closed! Push the other line further onto the filter, then compress the two plastic tabs inside the fitting. Pull the line off while those tabs are compressed.
Reverse the procedure with the new filter. Listen for the click of those plastic tabs to be sure that line is locked in place.
PONE
1998 Oldsmobile Cutlass 4 cyl Front Wheel Drive Automatic 183k miles
how do I know when my fuel filter is bad
Thursday, June 27th, 2019 AT 1:30 PM (Merged)
JDL
  • 16,098 POSTS
Hi, that is a maintenance issue. It won't hurt anything to replace once a year. There may be a mileage spec in your owners manual? If you wait until there are driveability issues because of fuel filter, you waited too long.
DJMARKO53
  • 6 CYL
  • FWD
  • 31,000 MILES
How do you release the plastic clip on the Fuel Filter on my 1997 Olds Cutlas? I can do the nut on the side coming out, but need to know how to release the plastice clip. Just want to make sure so I don't break something. My new Fuel Filter has a plastic clip on the one end. If I could get the old one off, I'm sure that it would all fit together.
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_olds_fuel_filter_1.jpg
You see the ears, one on each side, you squeeze those together, then pull. You need to make sure there is no pressure on the system, before you take anything loose. Loosen the gas cap, even then sometimes gas tries to run out of the lines, I just plug them with something till I'm ready to go back with the new filter.
As far as the quick connect fitting, I have taken them loose with a pair of needle nose pliers. I believe the auto store sells a cheap tool for releasing the fitting.
