Firing order?
ANABELL
  • 1998 OLDSMOBILE CUTLASS
  • 6 CYL
  • FWD
  • 123,704 MILES
Removed heads from a 3.1 liter took spark plug wires off coil packs did not mark them and the numbers on the coil packs r not the orginal james
Do you
have the same problem?
Saturday, November 22nd, 2008 AT 6:38 PM
  • 108,014 POSTS
Hi:
Standing in front of the vehicle looking at the the coil packs, there are three of them. From left to right, the first coil pack is 1 & 4, the second coil pack is 6 & 3, and the third coil pack is 2 & 5. Now still standing in front of the engine, the first three cylinders in front of the radiator are 2, 4 & 6 and the last three near the firewall are 1, 3 & 5.
The firing order is 1, 2, 3, 4, 5, 6 if it is a 2.8 or 3.1. What you did not say is what engine it has (2.8 VIN "W" or 3.1 VIN "T")
Let me know if this helps.
Thursday, December 11th, 2008 AT 4:25 PM
ZELAYA
  • 1995 OLDSMOBILE CUTLASS
Electrical problem
1995 Oldsmobile Cutlass 6 cyl Two Wheel Drive Automatic
Please I need the wiring order diagram for this 1995 Cutlass with 3.1 V6 engine.
Thanks in advance
Saturday, August 1st, 2020 AT 12:21 PM (Merged)
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_31_ciera_1.jpg
My info showed the above for a 3.1 ciera.
LDOWNER10
  • 1994 OLDSMOBILE CUTLASS
1994 Oldsmobile Cutlass 6 cyl Front Wheel Drive Automatic
what is the firing order for 1994 oldsmobile supreme cutlass 3.1 v6
There you go Merry Christmas
https://www.2carpros.com/forum/automotive_pictures/12900_fo_77.jpg
PISTACHIORICAN
  • 1991 OLDSMOBILE CUTLASS
  • 6 CYL
  • 90,000 MILES
I need to know the order of which the spark plug wires are put into the engine.
JDL
  • 16,098 POSTS
Hi, which cutlass do you have? What I looked at was cutlass ciera, 3.1L vin T
https://www.2carpros.com/forum/automotive_pictures/170934_ciera_firing_order_1.jpg
EDIEGO
  • 1986 OLDSMOBILE CUTLASS
  • 4 CYL
  • FWD
  • 30,000 MILES
I need to know what the firing order for the car is so that I can double check and make sure that its correct.
BMRFIXIT
  • 19,053 POSTS
4 cyl firing order is 1 3 4 2
let me know if need more
good luck
MIKE STEEL
  • 1985 OLDSMOBILE CUTLASS
  • 6 CYL
  • 100,416 MILES
Need firing order for 1985 olds. Cutlass v6. Please send firing order for distributor cap.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,554 POSTS
Hey Mike,
Here is the firing order and distributor rotation diagram you requested for a v6 Gm. Let us know if you need anything else we are here to help.
https://www.2carpros.com/forum/automotive_pictures/561653_firing_order_85_38_1.jpg
THIZZLLE
  • 6 CYL
  • 124,587 MILES
I know the firing order for my car its 1, 6, 5, 4, 3, 2 but I need a picture or something cause I dont know where these are like what wires is #1, 6, 5, 4, 3, 2 and where is #1 wire is it the one on the left closest to the bumper or closest to the windsheild I dont know?
I replaced my distributor cap and I thought I put wires on in the right order but theres a clicking sound from it and my friend said I put the wires on wrong thats why I need to know which wire goes where
BMRFIXIT
  • 19,053 POSTS
Best i can do hope that help
https://www.2carpros.com/forum/automotive_pictures/99387_olds_2.jpg
